Missing fixture in 3D easyview
- FreeStyler Version: 3
hello i have made a fixture in scan library and i cant seem to find it in 3d easy view can anyone help please
- FreeStyler Version: None
Re: Missing fixture in 3D easyview
Have you put it in the correct folder? Are you using BETA version?
- FreeStyler Version: 3.6.51
- I Use FreeStyler for: Band
Hi Nathan R93. What do you mean by putting in the correct folder? A strange thing happened to me ... I created a new lamp in FS but, in easyview it does not display it. I read that it must also be created in Scanlib. It's true?
If so, is there a simpler method? or a manual for using scanlib ???
Thank you so much
Thank you so much
Hi Drummer.
Yes you need to create a fixture profile for scanlib if there isn't one. It's separate program.
If you need help, post a manual and I'll see what I can do for you.
