Hello everybody,
I've created a 7 channel fixture for my Eurolite SLS-12 QCL LED-Pars. The first 4 channels are the colors (red, greeb, blue, white), the 5th one is the dimmer.
Usually the light don't show any beam when the dimmer channel is at 0, but in Magic 3D it is enough the open one of the color channels to show a beam. Dimmer channel has no effect at all.
I'd like to test my chasers with Magic 3D, but so it is impossible as the beams will always be shown.
And by the way: the white channel (added as "color mixing" channel) will not show any beam at all.
Thank you for your help!
LED-Par shows beam even with dimmer channel at 0 Topic is solved
lemon
SLS 12 QCL 12x5W.ssl2- (3.58 KiB) Downloaded 116 times
Nathanrs93
- FreeStyler Version: None
Re: LED-Par shows beam even with dimmer channel at 0
Explain that again?!? You're not making sense in what you've put? It's not showing light beam?
