20CentZ XXc007 (RED+GREEN laser)
Locked
IceSocket
Post by IceSocket »
This is the 20CentZ RED+GREEN laser with the model number XXc007 printed on the front panel. Everything is controlled from the macro panel, but I've also added the images to the gobo channels so the current pattern will show up on the Freestyler desktop. This is a pretty large build since all the patterns (gobos) has been drawn, 72 in total.
This is a low-cost, low-quality laser, imported directly from China (subject to rebranding when sold elsewhere). It uses 40mW green + 80mW red laser diodes on the same mirrors, so the beams always move togheter.
20CentZ-XXc007.pff
(458.56 KiB) Downloaded 180 times
davopcdj
Re: 20CentZ XXc007 (RED+GREEN laser)
Post by davopcdj »
the lazer i have sounds like the 1 u discribe how do i go about setting it up
FreeStyler Version: N/A
Post by remco_k »
davopcdj;
Please start your own topic for this.
And if you do, make a complete problem description of what is not working for you. Tell us what you have tried, what fixture you are using (brand and model). If neccesary attach an fixture file (*.pff) to your post.
Just asking us for help with no info, is not the way to go.
Locked
Return to “Lasers”
