HELP IM GOING INSANE Topic is solved
eddymonstar
Post by eddymonstar »
Hello ive be working with DMX for years but have just started using freestyler i have 2 omega1 scanners i can create the sequence and load it to cue but when i go top play the cue it only plays the first step then stops ive tried everything i can think of any help of what im doing wrong or what i should try would be awesome im hours away from launching the laptop out the window :)
FreeStyler Version: 4.01
Re: HELP IM GOING INSANE
Post by Partyman »
When you build the cue can you play it in the create sequence window and if so does it react the same?
