Magic 3D Easy View
heythereitsme
Magic 3D Easy View
Post by heythereitsme »
Hey, everything is working fine, i've unzipped the file etc, but placed objects (rectangles etc) just don't show. I see the wireframe of the item in other views, but in the main view they're invisible :cry:
buttza
FreeStyler Version: 3.6.4
Twitter: twitter.com/@buttza
Re: Magic 3D Easy View
Post by buttza »
Check the size of the items you are adding. You may need to make them large enough to view.
Also set your ambient light to half so you can see what you are building. :)
I think it is under resolution tab.
