Ayra ITA3D 600 RGB 600mW 3D ILDA DMX laser V1
numtek
Just started using FS
FreeStyler Version: 3.6.3
Post by numtek »
All colors work and all channels are correctly mapped to their respective categories.
I even included some macro's, for example all windows have an emergency stop-button.
None of the gobos match. I only used already existing gobo-pictures.
The effect wheel works like a charm, I mapped it to the second colorwheel.
Ita3d_600_rgb.pff
(385.49 KiB) Downloaded 91 times
numtek
Re: Ayra ITA3D 600 RGB 600mW 3D ILDA DMX laser V1
Post by numtek »
Well that was a suprise. I seem to have a model 'V1' and the only manual out there is for 'V2'.
This means that for turning the laser on I selected a value of 128 on channel 1.
If you have a model 'V1' like I do, you might want to set channel 1 to max (255), since this will mean that the automated parts of channel 5 and upwards are activated. If you set channel 1 to 128 like I did in this fixture and you press 'Laser on', the automated features (for example moving along the Y-axis, channel 5 value 128 and upwards) are disabled.
I'll leave the fixture as is since it seems there is more one model of this laser around.
Now if only there were multiple manuals as well,..
Below you can find the relevant parts of the only manual I have for this laser. As you can see, setting channel 1 to 255 should set a sound-activated mode. It doesn't.
Channel 1 [Mode]
0-63 Sound-active mode (disabling channel 2)
64-127 Automatic mode (disabling channel 2)
128-191 Manual mode, auto run function
192-255 Manual mode, sound-active mode
Channel 5 [Movement Y]
0-127 Manual Y positioning
128-191 Automatic down movement
192-255 Automatic up movement
Return to “Lasers”
