Request Briteq BT-LASER1500 RGB profile
raudio
FreeStyler Version: 3.5.4
Post by raudio »
Hello,
I need a profile for the Briteq BT-LASER1500 RGB (13 CH)
http://en.briteq-lighting.com/product/4 ... ER1500-RGB
[url]http://www.beglec.com/manuals/BT-LASER1500RGB.pdf[/url
Thanks in adavanced.
Paulo
Olivemx
FreeStyler Version: 4.1.6
Re: Request Briteq BT-LASER1500 RGB profile
Post by Olivemx »
Bonjour,
Je suis aussi à la recherche du fixture pour le Briteq laser 1500, est-ce que quelqu'un aurait ca ?
Merci
FreeStyler Version: 4.1.7
Post by Rod_Horning »
Olivemx
Post by Olivemx »
Bonsoir, oui c'est bien cet appareil
Attached is a fixture that should work with your instrument.
I have defined a color wheel with the single colors - the multiple colors can be added.
I have also defined a few CUSTOM SLIDERs. Others can be added if desired.
Also defined are a few MACROs. More can be added if desired.
The text is in ENGLISH. I can use GOOGLE translate to create a version with French text if you desire.
BriteQ_Laser1500.pff
(25.12 KiB) Downloaded 6 times
