Laserworld CS-1000 RGB
numtek
Just started using FS
FreeStyler Version: 3.6.3
Post by numtek »
After checking all available fixtures, none worked like they should so I created my own.
I've got most of the gobos right, still some left. I only used already existing gobo-pictures.
All colors work and all channels are correctly mapped to their respective categories.
I even included some macro's, for example all windows have an emergency stop-button.
Light, shutter, rotation, strobe, wave are all functioning and tested.
Chris Dodge
Re: Laserworld CS-1000 RGB
Post by Chris Dodge »
Thank you very much from France ;)
numtek
Post by numtek »
Yeah! You're welcome :)
Creator76
FreeStyler Version: 3.4
Post by Creator76 »
one question....
I've bought the ES-400 RGB.......can i Use the fixture from the CS-1000 RGB for my One ?!
I'm a little bit stupid to Create a Fixture for the ES-400 RGB.......need help pleaaase
numtek
Post by numtek »
Creator76 wrote:one question....
I don't think that will work. If you still need it, give me a shout, ok?
dinglestar24
I Use FreeStyler for: Band
Post by dinglestar24 »
Awesome, Thanks!!
Return to “Lasers”
