American DJ REVO III
crewl1
Post by crewl1 »
This fixture file is for 4 channel mode so set your fixture settings appropriately.
Channel 1 is mode (Pattern - Chase - Standalone)
Channel 2 is selection of pattern or chase 1 - 25
Channel 3 is chase speed or pattern strobe rate
Channel 4 is lamp dimmer
Check the manual for DMX values.
I also added macros for fast strobe, slow strobe, blackout and sound active.
REVO III.pff
(9.88 KiB) Downloaded 177 times
Djsynystr
Re: American DJ REVO III
Post by Djsynystr »
I tried using this and it wont import. somethign isnt right with valuse or something.
sirwesley
Post by sirwesley »
How do you configure this light to respond to the global blackout. I appreciate the fixture file, but what needs to be done to this file to get it to respond to a global blackout?
Shannon D
Post by Shannon D »
In order for a fixture to respond to the "Global Black Out", it has to have the lamp channel configured. Since this light does not have a specific lamp channel it won't work. I have the same problem with other LED fixtures. I created a "Black Out" scene with all LED fixture channels set to zero and all lamps turned off on my MH's. Set the black out scene as your favorite and use the favorite button for your global black out.
mmapplebeck
Post by mmapplebeck »
There is a very simple workaround to this. All you need to do for the Revo III, is open the ficture in FC, and set Shutter Ch. to 2, and closed value to 0. You can leave open blank, when you activate blackout, it will go blank, and when you turn blackout off, it will return to the previous value set.
Hope this helps
- Marc
Return to “American DJ”
