Need fixture briteq BTW07L12 wash
Jbsystem76
- FreeStyler Version: 3.5.5
- Twitter: Nean
hi greetings to all ... I need a new fixture for the new Briteq btw07l12 Wash 16 & 28 Ch Thanks
- FreeStyler Version: Beta
Re: Need fixture briteq BTW07L12 wash
Try English
- FreeStyler Version: 4.1.7
Attached is my attempt at the 16 channel version. I've also attached the user manual for convenience.
After you select the fixture you will want to click on Window All. You may need to move the windows around in order to see all 5 windows. You should see Colors, Macros, pan/tilt, custom sliders and shutter/intensity. of course the normal sliders in the upper right hand corner are also available.
I did not understand channel 13 so have not included macros or custom sliders. If you could explain the channel to me then I can probably add macros/sliders to help in its use.
If desired I can add custom sliders for the various functions of channel 1.
The macros in the Macros window control channel 15.
Channel 8 is controlled by (a) the Fixed colors tab in the Colors window and by (b) the 6 custom sliders. Please note that the color icons in the Fixed colors tab are what comes with Freestyler. They may or may not match what your instrument produces. They can be changed if desired.
The CMY-RGB tab of the Colors window may also be used to custom control the colors. To use this function the red/green/blue with white arrow icon must first be selected in the Fixed colors tab.
Please give this a try and provide feedback. I am willing to update the fixture file based on your feedback.
If no one else does so I will create the 28 channel version. I'm doing 2 major productions right now so it might be a week or so until I have the time and energy to work on the 28 channel version.
BriteQ BTW07L12 user manual.pdf- (3.12 MiB) Downloaded 20 times
BriteQ BTW07L12(16).pff- (147.55 KiB) Downloaded 15 times
montreau
Sorry for my first post.
thanks à lot for the file.
I try it soon (I hire them in few weeks). and give you a feedback.
The 16 chanel mode whas exactly what I expect, enough for us.
I'm curious to hunderstand how to use the led apart in a show.
Sylvain
Sylvain
