Reduce DMX400 chaser speed below minimum
Have a Tip? Share IT!
dsabola
Post by dsabola »
Hi, Is there a way (in the .inf file or something) to set the DMX400 chaser speed to go even slower than the pre programmed minimum, i.e. less than with the slider at zero>
Thanks a bunch!
Return to “Tips from the Pros!”
