Maybe this can already be done, but I'm not seeing how.
I already have a MIDI controller that has fancy knobs and faders and all that stuff, one of which I use for "Master Intensity." Works fine.
However, I think it would be nice if I could assign a similar "Intensity Setting" for a group of lights. For example (for my application) I would like to be able to assign a midi knob to control the master intensity for only my front lighting (e.g., during slow parts of songs I would like to dim the fronts and when the song kicks in to the chorus, bring them up! All while allowing the back-lighting to do whatever it would normally do - I'm assuming that the back-lighting is running on a sequence(s) that has nothing to do with the front lighting.) Simultaneously, I would like to have the ability to dim my back-lighting separately, using MIDI control. This is a simple example.
In other words, I would like to be able to selectively dim fixtures using MIDI knobs/faders (assuming they have an intensity channel,) but allow other not-selected fixtures to remain un-affected.
I could see a similar feature being useful for much more than just intensity.
Thanks!
Kendell
Selective intensity groups
- FreeStyler Version: 3.5.6
- I Use FreeStyler for: Band
- Spirit
- FreeStyler Version: 3.5.9
Re: Selective intensity groups
hi
you van do this by useing the Submasters.
the fixtures that are recorded to the Seq will be controlled by a Submaster intensitie slider.
- buttza
- FreeStyler Version: 3.6.4
I cheat with this.
I have front White wash on Channel 1 and 2. I assign DMX Channel 1 and 2 to their own midi sliders, 1 and 2. Then that way I have independent control of those since they are the only fixtures that I might need to pull back that is different from the Cues.
Oh, I think I get what you're describing Spirit. I'll play with that. Thanks!
