fixture for stairville cx3 8Ch [SOLVED] Topic is solved
redhead85
Post by redhead85 »
PAR 64 CX3 RGBW 8Ch.pff
Fixture
(11.43 KiB) Downloaded 44 times
I tried to make it on my own based on an other stairville LED-Spot, but I have no Idea how to get all these functions into my fixture. Please HELP
MANUAL Pt1
MANUAL Pt1
Manual Pt2
Manual Pt2
Re: fixture for stairville cx3 8Ch
Post by Jan_K »
Hej
You are on to the right thing when you place the channel 7 functions in the "macros"
I can see that you have placed the values in channel 1. That is wrong. They are to be in ch 7.
Also I would make the first value 0 to a icon with the text "OFF" because you switch off the macro / mode function and goes back to normal mode.
The chanal 5 I would place on the color wheel and then you have to find the value where it shifts colors and enter them in the table with a icon that matches. (also here you need a white or off as the first icon.
redhead85
Post by redhead85 »
Thaks!!! I will try that!!
With a bit more research, yesterday I did another one .... today is testing day ;-)
redhead85
Post by redhead85 »
thanks for your help!!!!
Everything works
here is the fixture for everyone else who needs it:
Stairville PAR 64 CX3 RGBW.pff
(132.1 KiB) Downloaded 69 times
