Hi Guys,
I have an RGB Led DMX device, but i want to allow this to use only one color at time ( Sound Activated )
CH1 = Red
CH2 = Green
CH3 = Red
CH4 = Dimmer ( this is a master dimmer, works with ch1 to ch3 at same time )
CH5 = Strobe
CH6 = PAN ( that device does not have tilt )
How to allow freestyler to use only one color at time, randomic selecting each color? there is a way to do that without CUES/Sequence? modify device on Fixture creator ? Any way to create a macro to do this and put on color window? create fake channel with 1..85 = red, 86..170 = green, 171..255 = blue that set rgb values ?
Ps. On this device mixed color is not good, bad efects.
Any sugestions will be apreciated.
thanks...
DMX RGB Led ( how to use only color at time ? ) Topic is solved
