Multiple Sequence Problem Topic is solved
djlootz
Hi, so Ill try and explain this the best I can. I have two chauvet intimidator led 300's and two chauvet colorrails that I use with Freestyler (current update). Ill make a sequence for the scanners that has color changing and head movement and insert that into the cue list, ill then make a sequence for the colorrails with basic color changing and insert that into the same cue list right below. When I activate both cues the scanners stop moving but resume color changing, as soon as I stop the colorrail sequence and allows the scanners to continue the scanners begin moving again, and when i start the colorrail sequence again they stop.....so basically anytime I activate the colorrail sequence it stops the scanners from scanning. I'm using the beziers shape maker in the pan/tilt options, and I made both the scanners and colorrails in transparent mode. I can't figure out what could be causing it, and its driving me nuts! Any help is much appreciated thank you!
- FreeStyler Version: 4.01
Re: Multiple Sequence Problem
even though you did not intend to you may have included the scanners in the colorrail sequence. Activate each sequence individually and see if a yellow asterisk pops up next to your colorrails AND your scanners while operating the colorrail sequences
