Synced lightshow to band using gomonkey
edoerfel
Post by edoerfel »
Check it out. This is part of my synced lights to a band using gomonkey third party software for freestyler.
http://youtu.be/LDZrJPlN-1E
Nathanrs93
FreeStyler Version: None
Re: Synced lightshow to band using gomonkey
Post by Nathanrs93 »
Hi
Good work there! I've been wanting something similar myself for a while, as I love the effect matrix blinders give from the back of a stage or wherever you put them. Good work with programming using gomonkey, never used it myself but good work!
Android Dev (Moderator)
FreeStyler Version: BETA
Post by Mattotone »
Those blinders are awesome,
How easy was the show to operate using GoMonkey?
What changes could be made to make it better?
regards
Matt
edoerfel
Post by edoerfel »
Gomonkey is extremely easy to operate!! I've been using it regularly every week at our church. I have a midi foot switch that someone in the band uses to go through the scenes.
One thing would help so much is if gomonkey had some sort of timeline or a way to automate the scenes so you could have the drummer on click and then you wouldn't have to have an extra person running lights who doesn't know the light scenes or is just too busy singing and playin guitar! (Me) lol
Here's another video of some lights.
http://youtu.be/EoDga-Z--fI
Make sure to watch the end of video. That's where they get epic.
I have a ton more of awesome light shows I will be uploading shortly.
edoerfel
Post by edoerfel »
Also, if you could see which scene you are on in the gomonkey app that would help a ton!
Post by Mattotone »
edoerfel wrote:Also, if you could see which scene you are on in the gomonkey app that would help a ton!
is that the android APP? I didnt think any one used so never added any features. but i you do il develop it.
Post by Mattotone »
Could you expand on the automation? as the scenes can be set to timers, loops and midi control.
edoerfel
Post by edoerfel »
I haven't been able to grasp how the timer works in gomonkey, it would be great to be able to put a piece of audio in, and program scenes to the audio track. So the drummer would push play and play to gomonkey and the lights would do their own thing! That's my dream.
edoerfel
Post by edoerfel »
Also, yes, the android app. I would use it all the time if I could see which scene I was on. I do a lot of lighting for different things all the time.
buttza
FreeStyler Version: 3.6.4
Twitter: twitter.com/@buttza
Post by buttza »
Are you running a track?
Have you used Ableton Live?
You could use ableton live to trigger your midi control. :)
edoerfel
Post by edoerfel »
I'm not currently using tracks but i'd like too. I have not used ableton live, I'll check it out.
edoerfel
Post by edoerfel »
I checked out ableton. Was on it all night. Not really sure how to trigger my gomonkey midi control from it. ??
edoerfel
Post by edoerfel »
hi, i am trying to make an automated show with gomonkey by triggerring gomonkey by midi notes through a DAW. im using Reaper. gomonkey needs an option to type in the midi notes bevause i cant get it to work. watch this video and youll understand.
https://www.youtube.com/watch?v=s7Va9t3 ... tu.be&hd=1
buttza
Post by buttza »
Did you get any further with this @edoerfel?
I use a LAN => Midi program called CopperLAN, it is awesome.
I think Go Monkey is a midi out only not in.
You may need to Midi map Freestyler Directly if you are triggering from a midi source. eg Reaper.
edoerfel
Post by edoerfel »
hi buttza, i figured it out! i am triggering go monkey with reaper, its pretty simple. :)
edoerfel
Post by edoerfel »
Here's a few more recent lights I've created using gomonkey.
http://youtu.be/v3B6e9l2YV8
http://youtu.be/oGO420utEso
Matt- I have gomonkey triggered by midi alongside a click track in the bands in ears using Reaper.
edoerfel
Post by edoerfel »
Any plans to make an updated version of Gomonkey?
