Chauvet Colorsplash 200B
crewl1
Post by crewl1 »
Fixture file for Chauvet Colorsplash 200B. May work for the LEDSplash 200B as I think they just renamed the light.
This fixture is for Freestyler only, no 3D visualizer, sorry.
Note that channel 1 is the mode select channel so you'll need to know the values so you can use the other channels for RGB, strobing, etc. Check the Chauvet website for Channel Value Table.
I included a few macros for my most commonly used settings.
Larry
200B.pff
(17.16 KiB) Downloaded 331 times
Richard Mills
Re: Chauvet Colorsplash 200B
Post by Richard Mills »
Thank you! You're an absolute legend. :mrgreen:
blaide13
Post by blaide13 »
Thanks for the 200B file and macros. I'm new and was wondering how do you turn the macros off? I can turn each one on by clicking on it, but don't see anyway to turn it off without shuting down the program.
FreeStyler Version: N/A
Post by remco_k »
Give the channels that are controlled by a macro other values. Like zero or so.
Shannon D
Post by Shannon D »
I thought I posted this fixture file a while back, but I have updated it since then. Here is what I am using now. It has a macro called backout to turn the fixture off when needed. I also added a couple static colors. Hope this helps.
Chauvet_200B.pff
(40.18 KiB) Downloaded 310 times
Return to “Showtec”
