Chauvet Swarm 5 9ch Request Topic is solved
dostie1
Post by dostie1 »
Recently picked up the Chauvet Swarm 5fx. Anyone know where I may find the fixture file for it? I'm working on trying to create the fixture but I'm also new to Freestyler and is taking me awhile to figure out. Appreciate the help guys!
Here's the manual to help out if needed....
http://www.chauvetlighting.com/products ... _ML_WO.pdf
Product Page:
http://www.chauvetlighting.com/swarm5-fx.html
-Chris
jopjop
Re: Chauvet Swarm 5 9ch Request
Post by jopjop »
Help please, thanks...
djkyps
Post by djkyps »
Please help with this fixture. Im prepared to pay someone. Really needed. Thanks Guys
Post by Jan_K »
Why not pay the complete library a visit.
I think it is in the new_14_05_01.zip
viewtopic.php?f=23&t=4528
djkyps
Post by djkyps »
Yes i noticed that fixture however does it seem incomplete? I'm getting the light tomorrow so will test. I'm learning all this however I may be wrong and fixture is complete.
Post by Jan_K »
I can see what you mean.
However all channals are there so you can control the fixture but there are no fancy buttons to press.
Post by Jan_K »
You can try this one.
Chauvet_Swarm_5_09ch_V1.pff
(97.44 KiB) Downloaded 89 times
djkyps
Post by djkyps »
Hi and thanks again . I cannot seem to get any control out of this except for a couple of pre-set loops. Strange. Is it apparent to you why? I've definitely set all channel s right. Other lights work fine.
djkyps
Post by djkyps »
Just tested and it the same exact options available on the old incomplete swarm. I see you added to the existing controls however they do not work properly. Id love to send you this light lol
Post by Jan_K »
If I read the manual correct then channel 1 has to be set to 255 and then you should be able to control it with the faders.
There is a macro button "DMX mode" it sets channel 1 to 255.
This is the only thing I can see which could make the fixture not reacting on the control.
alanv
Just started using FS
FreeStyler Version: 3.63
Post by alanv »
Thanx Jan for the upload. Most features seems to be working fine for me. Almost everything i need anyway.
I have found that the master blackout does not kill all the channels though
Post by Jan_K »
Hej alanv
It is a bit tricky with this type of fixtures as it is 3 fixtures in one. (Additional I don't have the fixture)
There are 3 different blackout One in Macros, one in Macros/ gobo and One in the color wheel 2.
I don't know if there are additional parts which need to be turned of to give a blackout.
Also the master "blackout" in FreeStyler don't work on blackout I have made for this fixture because it only works on intensity / shutter channels.
It could be an idea to add a master blackout.
alanv
Post by alanv »
Sorry for only coming back now. I got it sorted. You need to diable DMX first then blackout
