Help for scanner Night Sun sb005 [SOLVED] Topic is solved
francocampo
Post by francocampo »
This topic to ask for help for the scanner sb005, because I could not find her to be able to manually create in the fixture creator. Many thanks to all for the help you can give me. Excusme for my English
Franco
Nathanrs93
FreeStyler Version: None
Re: Help for scanner Night Sun sb005
Post by Nathanrs93 »
If this is the right one, maunal here: http://www.nightsun.net/download/users_ ... /SB005.pdf
It seems like a simple 10 channel fixture :)
francocampo
Dear Nathanrs93 thank you very much for reply, i create this pff file you can try for eventually mistake, greeting, and thank's for your time, excusme for my very bad english.
Franco
SB005.pff
(74.69 KiB) Downloaded 25 times
