Ultra bar 12
Nathanrs93
FreeStyler Version: None
Ultra bar 12
Post by Nathanrs93 »
Here is the 8 channel fixture
Focus = Ch4 - Colour Macros
Frost Channel = Ch6 Program Speed
2nd Frost Channel = Ch6 Sound Sensitivity
Ultra Bar 12.pff
(59.75 KiB) Downloaded 211 times
hfordlaw
Re: Ultra bar 12
Post by hfordlaw »
Thank you.
sorbimil
Re: Ultra bar 12
Post by sorbimil »
thks a lot
newbie84
FreeStyler Version: 3.2.1
Re: Ultra bar 12
Post by newbie84 »
Does anybody know how to control each individual LED? Rather than all 12 at once?
Re: Ultra bar 12
Post by Jan_K »
I just had a fast look in the manual.
It looks like you can only split in 6 sections meaning you can't control them individually.
You can 2 LEDs at the time and for that you have to create the 20 channel fixture in the manual.
newbie84
Re: Ultra bar 12
Post by newbie84 »
Jan_K wrote:I just had a fast look in the manual.
That's a bit unfortunate. I maybe should of looked into this before I purchased 4 of them!
The Chauvet Colorband Pix light is now looking more appealing although they're around £250-£260+ each and I only paid £130 each for the ADJ Ultra Bar 12s.
cool_Torsten
Re: Ultra bar 12
Post by cool_Torsten »
Thank you very much. I use ADJ Ultra Bar 9, it´s also fantastic. :fs:
polo5569
Re: Ultra bar 12
Post by polo5569 »
will this work for the ultra hex bar 12 as well?
mario453345
Re: Ultra bar 12
Post by mario453345 »
Need it for the HEX type (Ultra Hex Bar 6) as well
RoyBread
Re: Ultra bar 12
Post by RoyBread »
Can't get it to work at all. Each channel changes the color of three spots at a time, no combination seems to enable blue on the left side, and any fade between colors results in sporadic rainbow-like color changes, whereas I am simply trying to fade from one color to no color into another color.
Return to “American DJ”
