Greetings all,
What i want is to use the midi to dmx function.
but the 1 fader to multiple dmx channels.
so midi 86 to 64
86 to 54
86 to 44
86 to 34
normally i did it in the midi config but since last update i cant anymore??
is there another way to do it?
Greets
Spikie
midi fader multi dmx Topic is solved
- dmxlighting
- FreeStyler Version: beta
Re: midi fader multi dmx
Why you want to do this I can't figure but the simple solution would be to address the all fixtures to the same dmx address then assign the midi channel to control that address.
Would this work for u?
spikie
because i want to use the 4 RGB parcan all diffrent address to use them 1 by 1 and then just 1 fader for all the shutters... thats why:)
- dmxlighting
Well u can do that but look more at control through submasters with midi - u can't do it using direct DMX in the way u describe at the top of this thread.
spikie
How should i do that with submasters then?
cause i did try it to use the RGB shutter channel, program them and put them in the submaster but the channel didnt work when i use the submaster...
