Question about movement
ghiki
FreeStyler Version: 3.5.5
Post by ghiki »
Hello to all, I'm starter with Freestyler and I'm creating my own fixtures, the question is; I have "DUNE LAS40/G" laser, but the laser movement (horizontal/vertical) are in channel 6 and 7 BUT with values between 000 and 128, from 129 to 255 is the "auto movement". Is possible to assign to "pan" and "tilt" controls (8bit) but with values from 000 to 128 and not from 000 to 255?
dmxlighting
FreeStyler Version: beta
Re: Question about movement
Post by dmxlighting »
Yes but u will have to create the fixture profile yourself
ghiki
Post by ghiki »
I created myself, but here (in fixture editor):
I cant specify the pan/tilt range, is another way to do this? (this is to use x/y blue ball function to aim with the laser)
I pushed the laser figures in macros and not in "gobos", because this laser uses two channels at same time to "emitting" figures (one for "groups" and another for "figures in that groups")
Post by Jan_K »
Lasers are always tricky as they don't fit into anything.
I would use Gobo1 as X and then Gobo2 as Y.
Then you have the faders to fine adjust and you can then use icons to place the fader in the right range.
ghiki
Post by ghiki »
I will try it (anyway, is a bit tricky)
Post by Jan_K »
Something like this.
