1 = Red
2 = Green
3 = Blue
4 = Shutter
5 = Auto
6 = Speed
I have successfully programmed the fixture and everything works but... How do I configure the Strobe , Shutter and Speed ? All channel 4 does is determine which type of Strobe is happening but you need to use Channel 6 to speed the strobe slower or faster. How can I create the fixture so Freestyler knows that all channel 4 does is activate the strobe feature while Channel 6 is responsible for its speed ? It seems simple , but the issue im having is that for whatever reason the shutter channel on this fixture doesnt actually have a closed position. from 0-27 its just solid on, once you get to 28 it starts to Strobe , but then to change the speed u use channel 6. Ive tried setting up Channel 6 to control low, med fast and it does work. But using channel four as a shutter doesnt because , well it is more of a strobe ingage than a shutter. If i call it a shutter , than the Blackout feature for this par stops working
Thanks in advance
Russ
