Some feature idea Topic is solved
trapgunner
Some feature idea
Post by trapgunner »
Today I use Ableton with Freestyler works great, but I have some issues and I want to sync a lot of different types of light in different time together, much of the sync I need to use the Manual Trigger, but the Manual Trigger change the step for all lights together, so this make all very difficult.
One idea is make a manual trigger for each cue, so I can control it separated.
And today I saw this video and is very interesting how you can control the sliders inside the Ableton:
https://www.youtube.com/watch?v=SQAQtS8zlIQ
buttza
FreeStyler Version: 3.6.4
Twitter: twitter.com/@buttza
Re: Some feature idea
Post by buttza »
I would setup the cues. Then associate the each cue with a midi note. That way when you trigger your audio clip in Ableton, it should trigger the cue midi note in Freestyler. We do this with click trax.
Return to “Ideas and Remarks”
