I figured out how to use the slider on my Korg NanoKontrol 2 to control the front wash lights however, If I slide up to 50% on the slider it goes to 50%, after about 1 second, the lights go to 100%. This is the default setting in the sequence that is being used on the submaster.
From what I can see when you run it in the cue list, it loops by default. There for when I slide the fader to 50%, the sequence then repeats and pushes it to 100%.
I don't suppose there is a better way to get the fader to be absolute or LTP/HTP on Intensities?
I may have worded this wrong so please don't kill me with fire if you didn't understand my meaning.
