I have a problem I use light mixer Showtec showdesigner 1024 and can't get it work together with freestyler, I have connected it to Enttec usb pro.
Can anybody tell if its possible to get those 2 things works together.
Freestyler + enttec + showtec showdesigner 1024 [SOLVED]
- Spirit
- FreeStyler Version: 3.5.9
Re: Freestyler + enttec + showtec showdesigner 1024
FS needs a Dongle and enttec show desinger..need a Dongle.
From FS -> Enttec pro -> DMX cable -> Enttec pro -> Showdesinger..
- buttza
- FreeStyler Version: 3.6.4
You could possibly use Art-Net to connect.
"- ArtNet source
To run MSD Demo with an ArtNet source, make sure that the ArtNet source and the computer running MSD Demo are on the same network.
The network part of both IP numbers should be the same. So for a netmask of 255.255.255.0 the first three numbers of the IP address should be the same, for a netmask of 255.255.0.0 the first 2 numbers of the IP addresses should be the same and for a netmask of 255.0.0.0 only he first numbers has to be the same."
Might help. I run the Magic 3D Visualiser on a second computer and control it from my laptop with Freestyler using Art-Net. This allows me to spread the load on the GPU and CPU's.
Hope this helps.
"- ArtNet source
Hope this helps.
