Hello there!
I have a suggestion that may make future upgrades/plugins easier in regards to controlling the software.
I was thinking that you could support control interfaces through a plugin API.
The Freestyler side of this would just have to load the DLL, and then have a set of calls. Some would be called by freestyler, and some would be events triggered by the dll.
EG:
getInfo - Get a version, author, name, etc of the plugin
sendCommand - DLL would issue command like start sequence 1, select light number, etc.
I'm sure there are a myriad of programmers that would love to make plugins for this proggy.
Cheers
Feature Request: Control API
- FreeStyler Version: 3.3.6
- Spirit
- FreeStyler Version: 3.5.9
Re: Feature Request: Control API
you can use "Sendmessage"to do this..
you can find a Documentaion in the freestyler directory..
maby you allready noticed but there are allready a TON!! of other Software tools thats works with FS..
like:
LUAFS
GOmonkey
Showtime
Autostrobe timer
Sound to light
Easy freestyler interface
VJ Beat controll
and more i dont even know about...
like:
LUAFS
GOmonkey
Showtime
Autostrobe timer
Sound to light
VJ Beat controll
