Sound react
villeric
Just started using FS
FreeStyler Version: 3
Instagram: villeric
Sound react
Post by villeric »
Hello,
I do not understand why, but when I click that I want my moving light to react to sound it doesnt work
How do I select my sound card ??
Kings
Commited FS Forum helper
Re: Sound react
Post by Kings »
You need to click on the speaker icon on your Freestyler desktop to enable the sound to light function. A new screen will pop up and it will allow you to select the sound card via a setup option.
kittmaster
FreeStyler Version: 3.6.2
Re: Sound react
Post by kittmaster »
I've also noticed that when you do this, you also have to click the "trigger" button once to hook the sound option to start.....not sure if that is a global issue or something in my setup. But consistent when I run my system.
BillsGate
FreeStyler Version: 4.x
Re: Sound react
Post by BillsGate »
Also remember to enable sound-active for your chase in your cue window.
(as explained here: http://www.freestylersupport.com/wiki/p ... ns_options - 6th icon :) )
