1 button blackout -> lasers on Topic is solved
Bryzer
Post by Bryzer »
It would be cool to have a button witch you can press so all (or the pre-selected) the fixtures blackout and the (pre-selected) fixtures turn on. This does really come in handy when you have to switch from moving heads to lasers. It's really hard to get the timing right when you need to switch this fast. You first have to turn the moving heads off, then select the laser fixtures and turn them on. It does sound now as I'm typing this that it is nothing. But honestly, it is really hard to have the perfect timing. You're always a little to early or to late because of the button work. If this could be placed under one customize able button it would be great!
Also, if there is someone who has a tip for this it would be great!
dmxlighting
FreeStyler Version: beta
Re: 1 button blackout -> lasers on
Post by dmxlighting »
this could be done using 'cue list buttons' or 'override buttons'
scanlight
Post by scanlight »
you can use the override buttons to accomplish this
turn of/blackout everything, turn on lasers :fs:
Return to “Ideas and Remarks”
