Could use a little help
- chappaj
- FreeStyler Version: 3.5.2
- I Use FreeStyler for: Band
Hopefully you can steer me in the right direction. I am running version3.5.2 midiox is downloaded and seeing midi info from bcf how do I configure freestyler I have tried input as bcf and as midi yoke 1 Freestyler responds when I'm in midi edit mode user setup. If I push a button or fader it shows up. Once I save that it won't respond I'm the program to the midi functions is there a step I'm missing?
Chicks dig reverb
- Spirit
- FreeStyler Version: 3.5.9
Re: Could use a little help
hi
i'm not sure why you have troubles.
but why do you use midiox ?
and here is a link that have some usefull info
http://www.freestylersupport.com/wiki/e ... _interface
- chappaj
Sorry was half asleep when I started the message. I have gone thoroughly the wiki step by step. I understand there is really no need for midiox and midi yoke cause I am only using one interface. I started using it cause I could not get anything to work. It does show in the monitor windows of midiox that I am outputting from the bcf. Freestyler is seeing it too. It does not ever show in the monitor window of midiox that the computer is sending anything back to the bcf So this must be a configuration problem. After I input what I want each button and slider to do is there another step one that I am missing. Do you have to teach the buttons on the bcf? Sorry first attempt at midi in general so bear with me Thanks for the help
Chicks dig reverb
- Spirit
ahhh oke thanks for the info..
but I'm not realy sure what the issue can be.
but here some tips/question:
1. the BCF should be on BC MODE (can be found on the wiki)
2. how are the midi buttons/sliders mapped
3. besure you send CC# notes. can be monitored on Midiox, look for STATUS = 176 to 191 for DEC and B0 to BF for HEX
4. set midi INPUT AND OUPUT on BCF2000
5. if you press/drag a button/slider does fs react on it?
more I cant ask I think
- chappaj
Ok what is mapped I think this is where I'm going astray
Chicks dig reverb
- Spirit
hey sorry but that's not realy a imporent question.
ist alsmost the same as does your buttons / sliders send cc# note's
- chappaj
ok ill try to reply to each in hopes to get this right
the bcf is in bc mode and u-1
no mapping not sure what that is
midiox shows the sliders are outputing cc buttons above sliders in cc status is b0-b7 depending on slider or button data line is 00 in the output window it says port 2 input shows no port
in freestyler it shows that i am doing things cause the velocity changes but all the buttons are note 0 and sliders are note 7
i bought the bcf used does it need to be factory restored maybe?
Chicks dig reverb
- Spirit
ahhh yes
that's how the buttons / faders are mapped.
i'm not realy sure but I also have issue fs doesn't ouput correct on other Midi channels ( B0 to BF)
but FS works Perfect if everything is mapped on Channel 1 (B0)
but I recommend to upload this SysEx file to your BCF:
viewtopic.php?f=16&t=2189
you can also use the FMS (Freestyler Midi Settings) on that page only its made if you use Submasters..
but the SySeX file wil work for the BCF because all the buttons and sliders and encoders are MAPPED on channel 1...and they all have there own Note
- chappaj
Ha ok it is mostly working now but som buttons are in PC not cc that I know how to change but how do you get them to output in b0 some are still not doing that is it in the bcf manual edit where I change from PC to cc
Chicks dig reverb
- Spirit
never seen PC as Event...
if you like to edit button sliders or encoder I recommend to download the program BCMANAGER
http://home.kpn.nl/f2hmjvandenberg281/bcman.html
this is the only program that can Send Sysex file to different presets on the BCF.
BC_EDIT from behringer works realy crappy...
- chappaj
Thank you so much I have been scrambling to figure this out your a life saver. So I could potentially make two presets one for show use and one for ease of programming fixtures
Chicks dig reverb
- Spirit
yes indeed but I recommend to use the PAGE feature from freestyler..
because this will also update the fader, led and ledring correctly..
just keep it on 1 Preset
just a tip, DONT use preset 0 because this preset will not be saved on the bcf if you unplug the power...
- Kings
- Commited FS Forum helper
FS only responds to midi commands (buttons) that are a 'full strength' value of 127. You will need to program the midi controller to output this value when you hit a button. The software above will probably help you do this.
When entering midi vales into FS hit start, hit edit, push the midi button (should see the value appears) then hit edit again when finished...do not hit stop!
