Issues with Freestyler and Easy View 3D
michilson
Post by michilson »
I seem to be seeing a trend with Freestyler and Easy Viewer 3d and having several Options on a single DMX Value!
I have 2 Fixtures that seem to cause this issue!
American DJ Scan 250
1 Pan 0-255
2 Tilt 0-255
3 Color (0-28 Lamp Off, 29-57 White, 58-86 RED, 87-115 BLUE, 116-144 GREEN, 145-173 YELLOW, 174-202 ORANGE, 203-231 PINK, 232 - 255 PURPLE)
4 Gobo's (0-255)
When you place the DJ Scan 250 and turn on CH3 in Freestyler Easy 3d doesnt show any lighting effect on the Screen I have tried to adjust the Scan Library Setup for this fixture cant seem to get it to work.
I have had the Same issue with a 4CH LED fixture light the Chauvet Color Splash Jr.
CH1 Red (0-255)
Ch2 Green (0-255)
CH3 Blue (0-255)
CH4 (Strobe 0-127, Dimmer 128-255)
When you roll Ch 4 to 255 I get nothing but if i back down to 127 I get fast Strobe
The Dimmer and Lamp setings for fixture profiles in Easy 3d seem to not be working correctly. Maybe a option for the fixture creators is (LED fixture electronic Dimmers) andfor lamp fixtures ( Lamp is always on) A check box might fix these in there Preset Settings.
Or a preset Lamp on with any value above xxx!
Please let me know if you guys seem to have the same issues of if there is something I am missing!
Thanks!
Nathanrs93
FreeStyler Version: None
Re: Issues with Freestyler and Easy View 3D
Post by Nathanrs93 »
Hey
Did you read this michilson?
Read me!
If you read that and do what it says it should sort your problem, however if you keep having the problems after you've done what it says then reply and I'll see if I can help you out :)
/Nathan
michilson
Post by michilson »
Thanks That fixed it :)
Nathanrs93
Good 8-)
Maby
Just started using FS
FreeStyler Version: latest
Post by Maby »
Nathanrs93 wrote: 03 May 2013, 10:57 Hey
Read me!
/Nathan
I have the same problem
But your link does not work anymore. Does anyone has the solution? :) thanks!
Caloute
FreeStyler Version: 3.645
Post by Caloute »
Hello keen to read that doc as well
Cal
