Go to previous Not working?
djjasonk
Post by djjasonk »
I checked the go to previous box and start my cues with all of my lights off, and when I stop the cue or switch the using the cue list buttons all of my fixtures continue to run with the old setting unless a new message is sent. I had it partially working before, but I don't know how. This is my last step to getting everything the way I want it. I searched the forums and wasn't able to find a solution. I'm sure there's a step I'm missing or something. Any help would be great. :fs: Thanks in advance.
Re: Go to previous Not working?
hi
i tried it with Movements but it seems to Work oke.. if you mean "Restore Value"
But If you go to the CUE window. these a COG icon (options)
there a Option that says "Restore only intneisite channel" this need to be DISABLED.
otherwise it will only restore the intensitie channels..
djjasonk
Post by djjasonk »
Tried it both ways and didn't have much luck. If I click the active button it shuts everything off. So if I click the active button then the next button it works, but then I have a short gap of nothing. Is there a way to make it so when I click the next button it automatically shuts off the previous routine. Example: first scene has lasers and pars. Second scene has just the laser. I want the pars to shut off when I click the second scene.
oww whoops you use the Cuelist buttons.
same count for the Cuelist buttons.
Above the cuelist buttons you also have a COG wheel.
if you press on it you can Enable or disable "Restore only shutter channel" this need to be DISBALED..
djjasonk
Post by djjasonk »
I tried it with it on and off. Is supposed to terminate the last routine when you click the next button?
djjasonk
Post by djjasonk »
It works if I toggle the cue list buttons.
