I am completely lost on how to create this fixture for freestyler. Plus, every time I try to save my attempts, it gives me an error and I can't save. So I'm asking you guys.
It's a generic 15w Mini LED Moving Spot.
13 DMX Channels.
1-Pan (540 degrees)
2-Pan 16bit
3-Tilt (270 degrees)
4-Tilt 16bit
5- Speed
6- Shutter (0-7 CLOSE, 8-134 electrical dimmer, 135-239 Stobe effect, 240-255 OPEN)
7-LED RED
8-LED BLUE
9-LED GREEN
10-LED MACRO (0-7 no function, 8-21 white, 22-35 red, 36-49 green, 50-63 blue, 64-77 cyan, 78-91 magenta, 92-105 yellow, 106-119 purple, 120-133 orange, 134-147 chartreuse, 148-161 pink, 162-175 brown, 176-189 gold, 190-203 crimson, 204-217 violet, 218-231 crape, 232-255 movable macro)
11-LED Speed
12-Auto program (0-7 no function, 8-22 auto 1, 23-37 a2, 38-52 a3, 53-67 a4, 68-82 a5, 83-97 a6, 98-112 a7, 113-135 a8, 136-142 sound control 1, 143-157 sc2, 158-172 sc3, 173-187 sc4, 188-202 sc5, 203-217 sc6, 218-232 sc7, 233-255 sc8)
13- GOBO (0-12 open spot, 13-25 flower, 26-38 spiral, 39-51 flag, 52-64 hearts, 65-77 flowers, 78-90 stars, 91-103 spiral2, 104-116 flags, 117-127 flowers2, 128-191 positive rainbow effect, 192-255 negative rainbow effect)
I can scan the manual if that'd help, but all the info is above. Please, I've spent a lot of money to get this up and running, and I'd really like to get this working soon. Thanks guys!
Generic 15w Mini LED Moving Head Fixture Topic is solved
- FreeStyler Version: Beta
Re: Generic 15w Mini LED Moving Head Fixture
Hej jctodd
First I will not call this one generic as it only fits one fixture. (Generic to me is something that fits multipel fixtures)
I guess that you have seen some of the tutorials on the wiki.
If you get errors saving the fixtur you create then make it in small steps.
Just create a fixture with name image and the total number = 13.
Then save it.
Then add pan and tilt.
Then save it.
Continoue this step by step so you can see what goes wrokg.
Then save it.
Then save it.
- Kings
- Commited FS Forum helper
These sound familiar. Google the specs and you'll more than likely come up with a few different brand/model names like Sputnik. Once you have a couple search for it on the forum and also in the FS fixture folder on your computer.
- Kings
Ahh...try the Chauvet 'Min Spot' profile in FS!
