Difference between HAZE & FOG fluid....??
- Uriahdemon
- FreeStyler Version: 3.5.5
- I Use FreeStyler for: Band
Hi, I was wondering if there is a difference between fog and haze fluid. The reason I ask is that I have changed over to a hazer but have nearly 5l of Showtec fog fluid left. I was just wondering if they are actually different in make up and can they be used in both hazers and foggers...??
Mac
www.mclite.co.uk
www.mclite.co.uk
- Spirit
- FreeStyler Version: 3.5.9
Re: Difference between HAZE & FOG fluid....??
hi this depant on the Haze/Fog machine you use..
as i use the Antari Z-400 i cant put normal and cheap Fog/Haze fluid in it..
the Z-400 creates Haze to put the fluid under High presssure.
i also can produce Haze non-stop without the machine needs to heat up again.
i plug in the power and there comes the haze..
as other machines do it by a heating element.
these machines cant Produce fog/haze non-stop as they need to heat up each time..
