Submasters Pan and Tilt
Nathanrs93
FreeStyler Version: None
Post by Nathanrs93 »
Hey,
Just a quick question. I
I've noticed that most people put PAN and TILT as separate submasters and wanted to ask why and should I? I suppose that you have more control off your fixture, but it would take ages to program it all? I'm just asking in regards that I find it interesting but I'm unsure if I should do it and how I would do it?
I understand that you would have to program everything separate as you would normally, but not sure how you split it up in regards of 120 degree pan turn and then 120 tilt turn? If anyone could explain and help me out and tell me if it would benefit me, or if I should keep it as one and call it "movements" like I do now.
Best regards,
Nathan
Re: Submasters Pan and Tilt
hi this is how i use its the most easyiest way to create sequences in a matter of seconds..
http://www.freestylersupport.com/wiki/c ... equence:fx
and look at the SINE, COSINE, SAW example..
this one also looks nice
http://www.freestylersupport.com/wiki/t ... e_tutorial
http://www.freestylersupport.com/wiki/t ... _sequences
and this one to Fine tune the PAN MAX and MIN postion.
and Tilt MAX and TILT postion..
Nathanrs93
I've have a look at at that "FX" thing before couldn't get the hang of it, but I'll be sure to have another a look. Thanks Spirit.
CaptainBetty
Post by CaptainBetty »
I'll ditto @spirits comments.
I use the FX and I also use the moving head shape builder.
I put dimmer and pan/tilt swquences into their own sub groups. The dimmer has a full on/open and a few fade sequences built with the FX builder using intensity.
The pan/tilt sequences are just shapes I dream up or modify.
So when I go to run the scanners, I set the shape to play and dimmer sequence. From there I just mess with direct manipulation of colors/gobos - if needed.
To me, the idea of submasters is to separate out the functions of the fixture. I just wish the submaster panel was wider.
Nathanrs93
I agree with you CaptainBetty and would like if the submasters were wider.
Thank you for your reply, I'll be looking into it.
hi sante claus is a little bit late for you but wait on the New beta and maby the SM will be wider.. ;)
Nathanrs93
Spirit wrote:hi sante claus is a little bit late for you but wait on the New beta and maby the SM will be wider.. ;)
Oooooooo late birthday pressie :D
Uriahdemon
FreeStyler Version: 3.5.5
I Use FreeStyler for: Band
Post by Uriahdemon »
I have set up separate moves via FX on the submasters and it works fine.
Nathanrs93
Uriahdemon wrote:I have set up separate moves via FX on the submasters and it works fine.
Good to hear. I'm not doing anything with it at the moment as I'm planning on getting a new laptop, which I will hopefully be getting before the next event I'm doing. So then I should be able to use it as my current one keeps overheating on me :(
