Can Freestyler be configured to send different scenes to different lights based on what freq in the sound you are aiming for?
Say you want some lights to go to the bass, and some lights to go to the highs? Is that doable?
I want to see if it would work like this:
http://www.elementalled.com/apollo-jammer
Apollo Jammer
- FreeStyler Version: Beta
Re: Apollo Jammer
Hej b00t
The Sound to light function in FreeStyler only track the beat.
This means that you can control when the light are to shift.
It is not possible to set any frequency filtering and VU-meter funnction.
