Intimidator LED 150 "lamp on" problem? Topic is solved
Misty69
Post by Misty69 »
First, I'm using Chauvet Intimidator LED Spot 150's.
I've followed the Submaster tutorial, and I'm having a problem making the lamp turn on (or the shutter open, however you prefer) when I play back sequences, either directly from the submasters or from the cue buttons.
The shutter and strobe are on the same channel (channel 7), and the dimmer is on channel 8. There is no lamp channel for the fixture.
Any tips or suggestions?
Thanks,
Tom
DJ Eclectic
FreeStyler Version: 3.6
Re: Intimidator LED 150 "lamp on" problem?
Post by DJ Eclectic »
I am having the same problem. Mine are either strobing a tiny amount or strobing super fast.
