I have setup FS and EV which is working but very slow and clunky. I have brought down the rendering mode to normal and the resolution to medium.
I have this setup on another (older and less well equipped) PC and it is working OK. The particular PC I am trying to set up is much newer with greater CPU and RAM but it is still very clunky.
I am running Win 7.
Optimising EV3D and FS for playback on PC
- Uriahdemon
- FreeStyler Version: 3.5.5
- I Use FreeStyler for: Band
- Spirit
- FreeStyler Version: 3.5.9
Re: Optimising EV3D and FS for playback on PC
hi
i also run EV on a Very good pc and still cant set everything on HIGH!
pc specs, AMD Ahtlon FX 6200 (6x3,2GHZ) with 8GB ram
ATI 6870X2 CrossFireX with 2x1 GB GDDR 5 SDRAM 256Bit
2x SSD RAID 0, READ = 600MB/s WRITE = 600MB/S.
1200W PSU
and watercooled CPU... 28 Degrees Idle 35 Degrees Stress...
i can play battlefield3 on ULTRA high Grahics but EV3d View not
i think you need 8x Nvidea tesla Card to run it on HIgh mode only it cost more then 10,000 Dollars..
1200W PSU
- Uriahdemon
Thanks Spirit,
I have an older less capable PC set up which works as good as I need it. I have duplicated the settings from this onto another higher spec PC but cant even get the same performance as the less capable PC.....??
Rgds Mac
Rgds Mac
Mac
www.mclite.co.uk
www.mclite.co.uk
