Elation Midicon Topic is solved
heelium
Elation Midicon
Post by heelium »
Hello Everybody.
I read some threats in the fs-forum about the Elation Midicon.
But I'm still not shure if the controller works with FS.
Does anybody know if it works?
Most of all I would like to control the submasters with the controller and use the 8 faders also the buttons fwd, rev and play.
Maybe it is also possible to control the pan-tilt of all heads global with two of the jogwheels?
Thank you very much.
Markus
Re: Elation Midicon
hi
in theorie ALL midi controllers should work with FS.
only you need to understand how Midi works necause there are many differnt way's how a Controller can send Midi.
as i readed on the FSBT there is a someone how have some trouble with the Elation midicon controller.
because one Buttons send a NOTEON event (90) on NOTE 1 (00)
so 90 00 00
And therese a Slider thats send a Controller event (BO) on note1 (00)
So B0 00 00
Freestyler does not see the Deffernce beteen a 90 Or B0 events. for FS i recommend a B0 event..
so you need to use Midi ox or Bome's MT to Map al the button and slider so FS understand it.
