fine tune problem
zadzad
Just started using FS
fine tune problem
Post by zadzad »
hi hope someone can help.
last week i programmed a few sequences for some moving heads.
they worked fine till i went to use them today and now they dont seem to be running correctly, its like the x and y values have shrunk.
ive also noticed the fine tuning buttons are not working if i try and manually move the fixtures with these.
have i clicked on something by accident that would cause this?
when running the pre programmed shapes (including the ones i created) they are running correctly (x and y values are also correct)
thank you in advance for any advice
