American DJ Revo III Topic is solved
gdaddy
Is anyone familiar with, or has used, the Revo III LED light by American DJ and have they tried the FS with this light ... i'm trying, just very confusing ...
buster69
Re: American DJ Revo III
I have the impossibld which is the same light I believe, have you sorted afixture file yet ?
crewl1
Fill me in on what you'd like to do with the REVO 3.
I usually run mine in sound active and never really thought about wanting to run it DMX.
Note that channel 1 sets the mode (standalone, chase or pattern) then channel 2 selects the chase or pattern, channel 3 sets the speed and channel 4 sets the dimmer.
That's in 4 channel mode.
10 channel mode says it does the same thing but uses channels 2-8 for chase and pattern, and ch 9 for speed.
Mybe next week I will hook it up and test it out if no one creates a fixture before then.
Larry
Larry
crewl1
I played around with the REVO 3 in DMX mode and can only see additional benefit for me personally of:
blackout control, strobe all lamps and turning on/off sound active.
To me the patterns and chases by themselves are kinda boring.
You could program it yourself for a series of chases and patterns but IMO it's a waste of time since the built in programs are already pretty good.
I'll upload a 4 channel file with shortcuts for fast strobe, slow strobe, blackout and sound active in a little bit.
Remember that if you want to program it
Channel 1 is mode (Pattern - Chase - Standalone)
Channel 2 is selection of pattern or chase 1 - 25
Channel 3 is chase speed or pattern strobe rate
Channel 4 is lamp dimmer
Check your manual for corresponding DMX values. Larry
buster69
If This is the sme as the impossibled led could you share the fixture file please.
mamsoft
hi @ all,
i have a quastion about the revo III.
what means "stand-alone" in dmx mode?
(if i select the dmx mode and set channel 1 to standalone.)
is the stand-alone mode with or without sound to light in the dmx mode ???
or only patterns after another?
thx 4 answers
thx 4 answers
Kristoff
I'm new here so don't shhot me down if I'm being dumb
I'm investigating options for a friend who has an Impossibled and 2x Miracleds. Can anyone tell me a) what control you get over the Impossibled via DMX (colour etc?) and b) If there is a fixture file created for it?
I've yet to really use Freestyler and, as yet, don't have access to a USB-DMX dongle. Therefore testing isn't easy so far.
Thanks all.
Thanks all.
