Can someone advise me please,
I have some LEDJ lights - Blockbuster 6 and Stratos Wash.
There do not appear to be any fixtures created by anyone for these, if there are can someone tell me where please.
If I have to create them myself I need some advice with fixture creator.
The Blockbuster 6 seems different to other lights in that one channel is a master dimmer up to value 250 but setting it over 250 puts the light into "Preset" modes.
I guess I can put a limit on the dimmer range but should I create a macro which sets it into "Preset" mode
but then the other channels change thier function e.g. channles 3 5 & 5 are RGB when 1 is a master dimmer but go into "macro" (i.e. preset) mode when 1 is > 250
How should I approach this in fixture creator.
Also when I create the fixture the fist page show the number of channels used, but I cannot get the page where all the values (gobos strobes etc..) to appear.
The program seem to be intelligent as to which panels to make available and I cannot ovveride it.
Thank you
LEDJ Fixtures
RoySlough
RoySlough
Re: LEDJ Fixtures
I think I have the answer to the missing panels, it comes from what type of fixture is being created at the begining so I should be more careful in this choice.
I still need advice on how to manage the master dimmer/mode control
