need fixture lanta Quasar Emerald laser
Nathanrs93
FreeStyler Version: None
Post by Nathanrs93 »
I've had a look and can't seem to find the fixture, so was wondering if someone would create it for me as I'm not sure what I'm doing.
manual handbook.pdf
thanks
kristoffer
Re: need fixture lanta Quasar Emerald laser
Post by kristoffer »
Ok, try this one.. Not the best one i supposed, but it should work though. Otherwise let me know.
Emerald.pff
(58.29 KiB) Downloaded 53 times
Nathanrs93
thanks, i'll be sure to let you know. :D
Nathanrs93
i've tested this and it's missing patterns on channel 2? no macros or anything to select them? also it only opens the beam when you press strobe (i have beta downloaded because of moving heads), why is this? also i thought you could control it manual as well as automatic, but i can't seem to do that as there's no macros or buttons to do it??
i have made a easy view fixture to test it, but it's not the best. so i don't know if its right. Can someone check both fixture files and see whats going wrong for me? thanks
//nathan
Emerald.pff
freestyler fixture
(58.29 KiB) Downloaded 41 times
emerald laser.ssl2
3d easy view fixture
(9.63 KiB) Downloaded 45 times
Uriahdemon
FreeStyler Version: 3.5.5
I Use FreeStyler for: Band
Post by Uriahdemon »
Hi Nathanars93,
Did you ever get fixture files that worked for this laser please....??
Also sent you a PM.
Rgds
Mac
creature
Post by creature »
I have also tried this fixture file - without sucess :(
Have spent all day trying to sort without success
I have 2 units
If I dmx them together as master and slave set them up to sound to light they work as they should.
If I reset them to dmx settings to work with software/desk they dont work in sink :(
Also theres no black out on this fixture - which for me will prove a real pain as would like to cut down the mains leads on my trusses.
anyone had any further luck ?
