While looking for a more suitable and user-friendly solution to external MIDI controllers for FS, I came across these products. They basically give you various sizes and configurations of what looks like a more pumped up Enttec wing, all over USB. From what I read, you basically assign any key (or program launch) to a button via their mapping software. If this is the case, which I hope it is, then instead of using a keyboard, one can use this slick external device instead. They have 24,60,80 key setups, some with jogs and shuttles.
I will probably pick up one in the near future to play around with it, but if FS can work with a keyboard, then there is no reason it should not work with these wings !!!
http://www.piengineering.com/xkeys.php
X-Keys USB Keyboard Type Control Wings
