This is from the old forum
Honslow
Hi There
Would it be possible to implement freestyler so when you call a sequece or cue it does not only play back the first scene, but plays the whole sequence. That way you could use the buttons to change the lightshows and not just call only the first scene.
Ys.
Daniel Holsko - Denmark
LJ eXodus
I think it's an interesting proposition!
Skylight
Why exactly do you want this? que's are meant to be run by the sequence playback. While the over-ride buttons are for static effects like colors or strobe-effects. In the button window youre not able to change the speed or see at which scene your que is.
Besides, the que's are also programmable to keyboard shortcuts, so you can indeed change your sequence it with the push of a button.
Honslow
Sometimes it is required to have an override que that takes up more than one scene, then it would be nice to be able to run it as an override button.
But you are right you could also just use a keyboard shortcut for a sequence.
Possibility to use the buttons to change sequences
