Cheap LED Par?
- buttza
- FreeStyler Version: 3.6.4
Re: Cheap LED Par?
Where are you? Country?
We use the Tricolor LED pars from Showtech / Prolight. I think they are around $350 AUD.
We have been using them for almost 2 years. When we bought them they were about $800 AUD.
I would recommend these. Three in one color LED chips are better than the 108 1 watt LED types that use one color LEDs. That is my personal opinion anyways.
You can by the same lights from China cheap. I believe the parts are fine but you will need to take apart when you get them to makesure theere are no 'Loose'parts in side that may come loose during transit.
matt
- Admin
- FreeStyler Version: NULL
