Laserworld el 200 rgy fixture
terminator
- Just started using FS
- FreeStyler Version: 3.4.6
For all who have a problem with the laserworld el 200 rgy here are a 100% working fixture. all works but pan and tilt doesn`t work. Who can help me to correct the fixture pls post the fixture data in this theme. Here are my fixture:
- FreeStyler Version: Beta
Re: Laserworld el 200 rgy fixture
Please upload the manual or DMX table
terminator
here are the manual from the internet http://www.evsound.be/images/catalogus/el-200rgy.pdf
Hej Terminator
You have placed the XY control on pan / tilt.
In this case it is not optimal because the XY controls have two ranges with different functionallity.
Example:
X value: 1 to 127 static, like a normal pan control the figure is placed in a fixed position.
X value: 128 to 255 dynamic, the figur move in the x-axis direction and the value becomes a speed control.
Think it could be an idea to place the XY control on gobo wheel 2 and 3 because you can only benefit from the pan/tilt control as long as the blue ball are in the section that covers 0 - 127.
I don't have to much time the next 2- 3 weeks but I will try to modify you fixture to show what I mean
Example:
I just had a closer look on the manual and the Fixture.
I think there is something wrong.
In the manual Pattern are on Channel 2 in fixture it is made on channel 3
Strobe is in manual on channel 3, in fixture it is placed on channel 4.
terminator
hey jan_K
I can say that the laserworld el 200 rgy not for 100% works, becaus the laser is to old for the usb2dmx interface, thats at the most lasers from laserworld. You can buy a dmx pult there is the laser for 100% working. Pan and Tilt don´t works with the interface. Thats the problem the manual is not right at the dmx pult pan and tilt is channel 5 and 6 and the rest is right.
Ok that way around.
You don't have the correct version of the manual that fits the fixture.
I have tried that once with a no name laser.
I made a fixture that covered all the DMX channels. Then I managed to get an image on and then by moving the sliders in right side of FreeStyler one by one I could figure out what each channel controled but it was not a simple task because some of the channels had more functions.
The way I did the intitial search for functions was adjust one channel and see what it controlled and then return it to 0.
This I did for each channel some like animation speed had no effect at the beginning.
In the second search I adjused the one without any finction the a value and the tried all the other sliders to see when I had a change.
terminator
i´ve bought a dmx pult now it goes for 100%. My tip buy a dmx pult i have a dmx pult from ibiza sound it is easy and the laser goes for 100%. I´ve asked thomann and they have said that the dmx from all interfaces to new for the laser is. Thats by the most lasers from laserworld. With freestyler it doesnt go
// terminator
// terminator
