Hello!
I'm experiencing a problem with MIDI output. I'd like to connect it with digital sound mixer...
Input works fine and is type "B[channel] 07 [value]" (for example "B1 07 3E"). Output should be the same, but freestyler doesn't changes channel value, it's always set to E (for example "BE 07 3E"), despire it should have been "B1 07 3E".
With that problem, no matter what I do, it always changes only one (the same) fader
Any ideas how to change or fix that?
The settings are; NOTE is set to 7, page to 0 and channel is n.a. I thing the problem should be here?
MIDI output problem
- FreeStyler Version: 3.4.8
- Spirit
- FreeStyler Version: 3.5.9
Re: MIDI output problem
hi .
oke i have taken a look at it with my BCF2000.
and i send on B0 50 XX
and the output is also the same B0 50 XX
Maby its because your sending on Midi channel 2 did your allready tried that?
Thank's for help!
Hmm, how can I change Midi channel?
