I think I found a bug.
In FS, I've mapped keys to do different things - for example, to make fog, press "F".
In the new version, I've mapped the keys like I had them before, and everything works except fog. I've tried a variety of keys, no luck. I can do it in the old version though.
I tried creating a bug report, but it won't go saying it needs a Category (and there aren't any to choose). I also read the pink message above while posting, but the bug reporting link in it goes to a dead topic.
Could someone tell me if I've really found a bug, and if so, how to get it properly reported?
Thanks!
Tim
- FreeStyler Version: 0
- Spirit
- FreeStyler Version: 3.5.9
Re: I think I found a bug.
yes your right the "fog "function with the keyboard does not seem to work,
1)go to the freestyler bug tracker
2)login
3)Press link "Report issue/Request feature"
4)Choose project ">> Freestyler 512"
5)Select "Category"
6)fill in Summary and Description
and press Submit
i allready reported more then 100 Bugs so it should work ok
2)login
5)Select "Category"
and press Submit
Thank you! I didn't select the right project, which was why I couldn't submit the bug report. I've submitted it now.
Thanks again,
Tim
Thanks again,
Tim
