QTX Orbitor LED Fixture
lazersounds
FreeStyler Version: 3.3
Post by lazersounds »
Unfortantly this fixture uses 5 Channels for colours as contains Orange and White LEDS on seperate channels so the only way I can see to put them so you have some control on is on seperate colour wheels, so in order to be able to use them, you have to pull open that box with the sliders on the far right of the freestyler screen and drag over to 255 to light them up as set to default 0.
Red, Blue and Green On Dimmer Sliders like a Par can would be.
I know it sounds complicated but if you use these lights, your see what I mean when you open the fixture in Freestyler.
Enjoy :)
LED ORBITOR.pff
(8.02 KiB) Downloaded 98 times
Return to “QTX”
